API: Prime 7 - Excel. Matrix passing issues.
I managed to pass variables from Excel to Prime 7 and then back to Excel using Visual Basic. The code works as intended. Here is the code
Private Sub CommandButton2_Click()
Dim a, b, c As Integer
Dim RowNum As Integer
Dim Path As String
Dim MC As Ptc_MathcadPrime_Automation.Application
Dim WS As Ptc_MathcadPrime_Automation.Worksheet
Path = CurDir & "\" & ActiveSheet.Range("J4").Value
a = ActiveSheet.Range("C2").Value
b = ActiveSheet.Range("C3").Value
c = ActiveSheet.Range("C4").Value
Set MC = CreateObject("MathcadPrime.Application")
MC.Visible = True
Set WS = MC.Open(Path)
WS.SetRealValue "a", a, ActiveSheet.Range("D2").Value
WS.SetRealValue "b", b, ActiveSheet.Range("D3").Value
WS.SetRealValue "c", c, ActiveSheet.Range("D4").Value
WS.Synchronize
Set RawOut = WS.OutputGetRealValue("out")
ActiveSheet.Range("C7").Value = RawOut.RealResult
ActiveSheet.Range("D7").Value = RawOut.Units
End Sub
The issue arises when I try to pass multiple variables (100+) using an array or matrix. Meaning, taking an array or Matrix of size (n,1) from excel, add it to a variable in Prime (lets say, M), then using the elements of M to populate the Prime file and retrieving the output back to Excel.
Somehow, when I jump from single values to matrices my code crashes.
I found this thread
https://community.ptc.com/t5/PTC-Mathcad/communication-between-VBA-and-Prime7-SetMatrixValue/m-p/769060
where the OP seems to have the same issue. I tried all the solutions there but I keep getting errors. I can't even define a matrix using
Set matrix = WS.CreateMatrix(3, 3)
As one anon did.
Anyone has any idea how to do this?
Thank you!
terryhendicott
Here is the visual basic version:
Imports Ptc.MathcadPrime.Automation
Public Class Form1
Private MCApp As Ptc.MathcadPrime.Automation.ApplicationCreator
Private WS As Ptc.MathcadPrime.Automation.IMathcadPrimeWorksheet3
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Try
MCApp = New Ptc.MathcadPrime.Automation.ApplicationCreator
MCApp.Visible = True
Catch
MessageBox.Show("Issues starting Mathcad Prime")
End Try
Dim Directory As String
Directory = System.AppDomain.CurrentDomain.BaseDirectory()
OpenFileDialog1.InitialDirectory = Directory
OpenFileDialog1.ShowDialog()
Try
WS = MCApp.Open(OpenFileDialog1.FileName)
Catch
MessageBox.Show("Couldn't open file, make sure you selected a valid file")
End Try
Dim pI As IMathcadPrimeInputs
pI = WS.Inputs
Dim c As Integer
c = pI.Count
Dim alias1 As String
alias1 = pI.GetAliasByIndex(0)
Dim pO As IMathcadPrimeOutputs
pO = WS.Outputs
Dim b As Integer
b = pO.Count
Dim alias2 As String
alias2 = pO.GetAliasByIndex(0)
WS.SetRealValue(alias1, 11.5, "km")
TextBox1.Text = alias1 + " - " + alias2
Dim i As Integer
Dim matrixValue As IMathcadPrimeMatrix
matrixValue = WS.CreateMatrix(3, 3)
i = matrixValue.SetMatrixElement(0, 0, 2.5)
i = matrixValue.SetMatrixElement(0, 1, 4.0)
i = matrixValue.SetMatrixElement(0, 2, 3.1)
i = matrixValue.SetMatrixElement(1, 0, 1.5)
i = matrixValue.SetMatrixElement(1, 1, 3.6)
i = matrixValue.SetMatrixElement(1, 2, 5.0)
i = matrixValue.SetMatrixElement(2, 0, 7.2)
i = matrixValue.SetMatrixElement(2, 1, 4.8)
i = matrixValue.SetMatrixElement(2, 2, 6.8)
WS.SetMatrixValue("B", matrixValue, "")
Dim hereResult As IMathcadPrimeOutputMatrixResultAs
Dim rowCount, colCount As Integer
hereResult = WS.OutputGetMatrixValueAs("here", "")
rowCount = hereResult.MatrixResult.Rows
colCount = hereResult.MatrixResult.Columns
Dim dblhere As Double
For i = 0 To rowCount - 1
For j = 0 To colCount - 1
hereResult.MatrixResult.GetMatrixElement(i, j, dblhere)
RichTextBox1.AppendText(dblhere.ToString)
RichTextBox1.AppendText(", ")
Next j
RichTextBox1.AppendText(Microsoft.VisualBasic.ControlChars.NewLine)
Next i
' Close
’Try
'WS.Close(Ptc.MathcadPrime.Automation.SaveOption.spDiscardChanges)
'Catch
'MessageBox.Show("Couldn't close worksheet, make sure Mathcad Prime is running")
'End Try
End Sub
Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
Try
MCApp.Quit(Ptc.MathcadPrime.Automation.SaveOption.spDiscardChanges)
Catch
MessageBox.Show("Couldn't close Mathcad Prime, make sure Mathcad Prime is running and all changed worksheets are closed")
End Try
End Sub
End Class
terryhendicott
The following code "Inputs" into Prime worksheet a 3 x 3 matrix.
Prime multiplies the matrix by three.
Prime "Outputs" the now larger matrix to the calling program and displays it in a rich text box.
The program works by hitting a go button.
It is programmed in Visual Studio 2019 in C#.
The actual code is as below.
I have enclosed a zip file with the mathcad sheet and the visual studio solution.
The file worksheet name is hard coded
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using Ptc.MathcadPrime.Automation;
namespace PrimeMatrix
public partial class Form1 : Form
public Form1()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
var appCreate = new ApplicationCreatorClass();
ApplicationCreator app;
app = (ApplicationCreator)appCreate;
IMathcadPrimeWorksheet3 ws;
ws = (IMathcadPrimeWorksheet3)app.Open(@"F:\\Prime\\VB\\Test.mcdx");
app.Visible = true;
IMathcadPrimeWorksheet wsTest = app.ActiveWorksheet;
ws = (IMathcadPrimeWorksheet3)wsTest;
IMathcadPrimeInputs input = ws.Inputs;
int countinput = input.Count;
String alias = input.GetAliasByIndex(0);
IMathcadPrimeOutputs outputs = ws.Outputs;
int b = outputs.Count;
String alias2 = outputs.GetAliasByIndex(0);
ws.SetRealValue(alias, 12.5, "m");
textBox1.Text = alias + " - " + alias2;
int i = 5;
IMathcadPrimeMatrix matrixValue = (IMathcadPrimeMatrix)ws.CreateMatrix(3, 3);
i = matrixValue.SetMatrixElement(0, 0, 2.5);
i = matrixValue.SetMatrixElement(0, 1, 4.0);
i = matrixValue.SetMatrixElement(0, 2, 3.1);
i = matrixValue.SetMatrixElement(1, 0, 1.5);
i = matrixValue.SetMatrixElement(1, 1, 3.6);
i = matrixValue.SetMatrixElement(1, 2, 5.0);
i = matrixValue.SetMatrixElement(2, 0, 7.2);
i = matrixValue.SetMatrixElement(2, 1, 4.8);
i = matrixValue.SetMatrixElement(2, 2, 6.8);
ws.SetMatrixValue("B", matrixValue, "");
IMathcadPrimeOutputMatrixResultAs hereResult = ws.OutputGetMatrixValueAs("here", "");
double wshereResultRowsCount = hereResult.MatrixResult.Rows;
double wshereResultColsCount = hereResult.MatrixResult.Columns;
double dblhere;
for (int ic = 0; ic < wshereResultRowsCount; ic++)
for (int jc = 0; jc < wshereResultColsCount; jc++)
hereResult.MatrixResult.GetMatrixElement(ic, jc, out dblhere);
richTextBox1.AppendText(Convert.ToString(dblhere));
richTextBox1.AppendText(", ");
richTextBox1.AppendText("\n");
terryhendicott
Public Class Form1
Try
Catch
End Try
Try
Catch
End Try
pI = WS.Inputs
Dim c As Integer
c = pI.Count
pO = WS.Outputs
Dim b As Integer
b = pO.Count
Dim i As Integer
Next j
Next i
' Close
’Try
'Catch
'End Try
End Sub
Try
Catch
End Try
End Sub
End Class
