append/excel
My program calculates several series of input data. I want to store all the outputs in an excel file. Is there similar function to "Appendprn" for excel file?
Thank you.
Werner_EAnswer
Look at the attached sheet.
Guess it should do the job.
Lookup WRITEEXCEL in the hep.
As Werner said lookup WRITEEXCEL and there are also loads of scripted components in forum which have been developed which do similar.
That's if you are not using Prime.
WRITEEXCEL supports OpenXML (*.xlsx) files.
Depending on your needs WRITECSV might be an option, too.
payman1-VisitorAuthor
Thank you.
But it overwrites the previously calculated values.
PAYMAN RAJAI wrote:
Thank you.
No, it doesn't. You decide where the data should be written. An Excel file is not a sequential data file, so there can't be that sort of append. You have to provide some sort of counter to be able to write the data at the correct position.
As an alternative you could read in the whole Excel file with READEXCEL in a Mathcad matrix, stack that matrix on top of the new data and write the new matrix with WRITEEXCEL at position A1.
Link to Excel Inputs
Video Link : 5443
Output to Excel
Video Link : 5445
MathCad/Input file/ppt
