Dec 10, 2020 1:18 AM UTC
augment a group of matrices
Hello, I would like to know how to program the union of four or more matrices, as shown in the
attadhed sheet developed in mathcad 15. Thanks
Werner_EAnswer
Dec 10, 2020 3:44 AM UTC
In case that for some reason you don't want to use augment (why?) and are looking for a replacement, you may use something like this:
Dec 10, 2020 3:28 AM UTC
I'm not sure what you mean by "to program" in this context.
What's wrong with the use of "augment"?
But if your question is how to write a function with a variable number of arguments, then the answer is - not at all, because this is unfortunately not supported by Mathcad for user-defined functions. A workaround solution is to pack all arguments into a vector and pass it as a function argument. Here's an example:
Werner_E25-Diamond IAnswer
Dec 10, 2020 10:51 AM UTC
Thank you very much, I really appreciate the support
