8-Gravel
Auto Calculation
When I tend to open up the worksheet in Mathcad Prime 8 does it auto recalculates the worksheet on its own or do I have to manually calculate the worksheet ?If yes In which scenario does it recalculates the worksheet?
Best,
Sam
DJNewman
From Mathcad Help Center:
"When you open a worksheet, PTC Mathcad Prime does not recalculate results automatically even if Auto Calculation is enabled. You must click Calculate or press Ctrl+F5 to recalculate the worksheet and view the final results. The recalculation is important when you are working with legacy PTC Mathcad worksheets that you converted or with files that contain included worksheets."
PTC Marketer for Creo and Mathcad. I run their YouTube channels, some Creo campaigns, and all Mathcad campaigns and communications.
Community Moderator
Hi @SS_9781956,
Anurag
