Automate saving of Mathcad file
Hello Mathcad Community,
I am currently trying to automate a Mathcad script using its Automation API. I am able to write values from Matlab/Excel to Mathcad and retrieve calculated values by return. What I would like to do is set the value of variable definitions and save a version of the Mathcad sheet with each iteration thereby generating a Mathcad sheet per iteration. Can you help?
The key is to take a set of data, pass it to Mathcad case at a time to a template sheet, save each case run as a seperate sheet automatically and then move on to the next case. To give context, I may have fifty sets of data and need to show the woking for each of the cases and not just in a table. Currently this would have to be done manually 1 at at time, which does lead a little bit of time consumption.
As templates are not available in Mathcad Prime am looking at using Mathcad 15 unless there is a solution to accomodate this in Mathcad Prime.
Thanks in advance.
Templates should be available in Mathcad Prime 3.0 version.
i need the same stuff.
I need a autosafe after each calculation step. On which i have a mathcad file for every load step. Generating. Is it possible with mathcad 15?
Example:
Calculating Load step 1
autosave with i=1
next step and so on.
