automatical change of input
i have question about repeating calculating of sheet. I would like to type a program where is important change input according on the result. Example.
a=1,1
X:=some equation
X=6
and it is less than I need, so I need to change the a argument. I need to by it automatically.
Thank you for answer.
Tomáš Martinka
A "solve block" is probably the closest to your request.  Look them up.
23-Emerald V
But for some cases, especially if you have a single equation, the root() function may work just as well.
An example:
So for x=1.165, f(x)=5.
tmartinka1-VisitorAuthor
But saidly i have more complicated case. I am trying to use FEM for calculating of load capacity. So I have load classes and I need change classes automatically when is load from choose class less than allowed load..
23-Emerald I
It might be challenging to do (it's impossible without seeing the sheet) but you might be able to rewrite your calculation as a function of the input.  It would then be possible to execute one or both of the options above.
