Available in the Mathcad tools do not allow to find the minimum of a function constructed from 10 Rosenbrock functions.
I'm looking for a ready-made algorithm "Direct search" (D.M. Himmelblau, Appled Nonlinear Programming, 1972) in Mathcad before 14. Is there such anyone? Thanks in advance.
J. Reyzenkind.
23-Emerald V
Яков Рейзенкинд wrote:
f(x,y)= (100*(y1-x1^2)^2+(1-x1)^2)+(100*(y2-x2^2)^2+(1-x2)^2)+...+(100*(y10-x10^2)^2+(1-x10)^2)
This is a test function .
Perhaps the attached worksheet may be worth looking at; it uses the Hooke-Jeeves method.
Stuart
Modified version of worksheet posted in thread Hooke-Jeeves function TOMS178
Some time ago there was a similar topic, here: Want to write MathCAD programm based on Maple 13 Code . Perhaps Walter has found a solution to this problem, try to ask him by using private message.
Vladimir, thanks for the tip!
No problem.
Just note that in addition to the implementation of this algorithm in Maple there is a whole toolbox in MATLAB (is called "Genetic Algorithm and Direct Search Toolbox"):
MATLAB Central - MathWorks - Genetic Algorithm and Direct Search Toolbox -
Genetic Algorithm and Direct Search Toolbox - Математика - Matlab.Exponenta.Ru
