Sep 2, 2010 5:35 AM UTC
Bad login
I recently ran into the situation where the forum would only recognize me as a guest (despite my being logged on to the PTC site. I was able to contact PTC via the collaboratory, after which the problem cleared up.
But what am I to do if this happends after the collaboratory is no longer available. As a guest I seem to have o capabilitites to leave messages at all. Do I just wait and hope that somebody notices the discrepency? Or do I take the easy (normal) and just quietly lose interest in the whole forum?
Sep 2, 2010 6:37 AM UTC
No.
We want experienced Mathcad users contributing to this forum.... So, PTC pull your finger out.
I have just had an error message several times while trying to login.
Mike
Sep 2, 2010 6:38 AM UTC
That same situation has happend to me a few times before. Even just tonight when I was trying to respond to jmg's post! It seems the login in doesn't register or something like that. Login functionality usually returns within a few hours or so.
Sep 2, 2010 6:46 AM UTC
Stephen,
What time was you trying to login?
Jean has stated several times that the site is down between certain times.
Mike
Sep 2, 2010 4:18 PM UTC
It was yesterday evening, maybe 10pm?
Sep 27, 2010 7:40 AM UTC
Me too. Several times.
There are not very much options ... at least, I can't figure others.
Regards. Alvaro.
Sep 27, 2010 1:18 PM UTC
Alvaro,
Does the Guest login still occur? Can you give me as much detail as you can? Time of day, length of time, process flow
-Dan
Sep 27, 2010 2:35 PM UTC
BostonDan wrote:
Alvaro,
-Dan
I email to -; answering
> Hello Alvaro,
> Examining the hyperlink you provided below, (Iniciar sesión), we noticed it contains “uat.” http://uat.communities.ptc.com/index.jspa is not a valid URL and should be removed from any bookmarks, cookies and cache.
> Please use http://communities.ptc.com to access PlanetPTC Community going forward.
> The Planet PTC Community Team
Apparentlely it is an issue from the spanish interface (index.jspa) and seems that my problem was solved. It is persists, I go to notify here. Thanks for your interest.
Regards. Alvaro.
