Basic Plot with Units - Problem
Dear Friends,
I'm quite new in Mathcad. I have basic question: I'd like to plot a graph of sin() function. I'd like to have argument of time in seconds and return values in Volts. If I insert for X-axis (which is variable t) unit s, Mathcad automatically makes this axis unitless [(1/s) *s]. What am I doing wrong? I know that I cen generate vector o time samples t:=0s,1s..10s but I don't understand why can't I simply change units from unitless to seconds?
I attached picture.
Thank You very much in advance for help.
Best regards,
Wojciech
23-Emerald I
You never specified that t had unit time.  Mathcad will let you plot a function of an unspecified parameter, it assigns values from -10 to 10.  There's a clue:
Mathcad will force units to balance; so when you typed the s in the units placeholder, Mathcad divided it by the time default unit.
Valery defined a range variable with units:
to get his plot to work with units.
-MFra-
wslowik1-VisitorAuthor
Thank you very much Valery Ochkov, Fred Kohlhepp and F.M. for your answers! Now it is clear for me that in order to work with the units I have to first define range variable, which at the same time, defines units for x-axis (in my case).
Best regards,
Wojciech
