bessel functions
Hi, I am trying to use bessel functions ber and bei and keep getting an error "Found a number greaterthan 10^307".
I do not think the answer will go beyond 10^307.
Simple way to see the issue is
Evaluate ber(0,78)=
Is this a known issue with M14? - John
On 1/18/2010 7:18:23 PM, jmG wrote:
>On 1/18/2010 5:12:55 PM, John_8490
>wrote:
>>Thanks Stuart.
>>That works...
>>I just found the same here
>>http://www.2dcurves.com/gamma/
>>gammabs.html
>>-John
>_______________________
>My calculations give
>ber(0,78) = -1.614E+22
>jmG
________________________
As declared, however no true value can exist.
jmG
23-Emerald V
January 19, 2010
>wrote:
>>Thanks Stuart.
>>That works...
>>gammabs.html
>>-John
>jmG
Possibly it can.
Stuart
23-Emerald V
January 18, 2010
On 1/18/2010 3:43:41 PM, John_8490 wrote:
== Hi, I am trying to use bessel functions ber and bei and keep getting an error "Found a number greaterthan 10^307".
== I do not think the answer will go beyond 10^307.
I think it should be about -8.757*10^21
== Simple way to see the issue is Evaluate ber(0,78)=
OK
Try replacing it with:
Ber(n,x):=Re(Jn(n,x*exp(3πi/4)))
== Is this a known issue with M14?
Don't know, but it's an issue with M11 as well.
Stuart
Thanks Stuart.
That works...
http://www.2dcurves.com/gamma/gammabs.html
-John
On 1/18/2010 5:12:55 PM, John_8490 wrote:
>Thanks Stuart.
>That works...
>gammabs.html
>-John
jmG
>go beyond 10^307.
>Evaluate ber(0,78)=
>M14? - John
____________________________
As long as it plots, you may be able to cay in formulas ! For the numerical local evaluation, check for any recurrence.
jmG
>>go beyond 10^307.
>>Evaluate ber(0,78)=
>>M14? - John
>cay in formulas !
>recurrence.
>ber(0,77) calculates ... plots up to 43
Attached: roots up to the max built-in capability 43
>jmG
