Apr 13, 2020 10:04 AM UTC
Bode Diagram Plot
I am at my first steps with Mathcad, could someone help me to plot the bode diagram of the function G(f) pease
Where
and
ML
23-Emerald V
Apr 13, 2020 10:13 AM UTC
Please first enter your formulae onto a Mathcad worksheet and attach that worksheet to your posting.
Apr 13, 2020 10:19 AM UTC
I randomly established the values of the constants.
ML21-VisitorAuthor
Apr 13, 2020 11:46 AM UTC
Thanks for your answer but could you please explain how did you get the definition of the frequency range ; and some steps to plot the diagram as you did.
thank you,
ML
Apr 13, 2020 12:23 PM UTC
You can define the frequency range taking as minimum frequency the smallest value among the absolute values of the poles and zeros and as maximum value of the frequency range, the maximum value among the absolute values of the poles and zeros. The step amplitude can be defined dividing the difference of the previous values by the number of steps. I have considered as a minimum value of the frequency Fz divided by a thousand and as a maximum value, Fp multiplied by one hundred. To have a larger diagram you can replace a thousand with ten thousand and one hundred with a thousand or ten thousand or even more, that is, they are chosen according to your needs.
