LucMeekesAnswer
23-Emerald V
Jun 21, 2021 8:58 PM UTC
No, they should not.
You did not define the variable 'freq'. This means that you left it to Mathcad to pick a suitable range for frequencies when you created the 'autoplot' (which is a nice feature, but as all features: to be handled with care).
In the case of mathcad 11, it took a linear range, starting at 10 (maybe) and stepping to 10^9 with steps of 10^6. That is why there are no (additional) points in the range of freq between 10 and one million.
In the case of mathcad 15, it probably took a range of frequencies logarithmically spaced from 10 to 10^9 with maybe 20 points per decade.
If you add this,
above the plot, tou your Mathcad 11 sheet, the you have defined freq as an array of frequencies, logarithmically spaced from 10  to 10^9 at 20 points per decade. And f is an index into that array.
Now all there is left to be done is to handle freq as an array in your plots, so add [f at the end each occurrence of freq in your plots.
Note that in mathcad 15 a function logspace() is available that can create a similar array.
LucMeekes23-Emerald VAnswer
23-Emerald V
If you add this,
Cornel19-TanzaniteAuthor
Jun 22, 2021 5:57 AM UTC
All the results below in the graphs are taken from Mathcad 11.
With
Case 1:
Case 2:
Case 3:
Without:
Case 1:
Case 2:
Case 3:
On the other hand, what I find a little strange is that in Mathcad 15 once I checked the box corresponding to the x-axis in which I specify to the graph that the x-axis represents a logarithmic axis then I don't have to create a variable for the x-axis so that I clearly specify that the x-axis is a logarithmic axis because I created a variable to do this, while, as you say, in Mathcad 11 I have to create such a variable even if I checked the x-axis box in which tell him that the x-axis represents a logarithmic axis.
Therefore why in Mathcad 15 I do not have to create such a variable to take into account that the x-axis represents a logarithmic axis (it is enough only if I specify in the graph properties that the x-axis represents a logarithmic axis), and in Mathcad 11 do I have to create such a variable that takes into account the fact that the x-axis represents a logarithmic axis (even if in the properties of the graph I checked that the x-axis is a logarithmic axis)?
And could you put a Mathcad 11 file with the implementation of the version you are talking about?
It would be useful for me to have an example as an example 🙂
(Attached is a Mathcad 11 File)
Thanks.
23-Emerald V
Jun 22, 2021 6:40 AM UTC
You forgot to put f as an index to freq every where you use freq in the plots.
