Bug in Mathcad 15 M030 (symbolics)
I would call this behavior a bug. The integral is only found if the symbolics is forced to float mode (it also happens if you use the "float" keyword).
Does anybody know when it was introduced or can anybody confirm the bug in earlier versions of Mathcad than M15 M030?
‌It works in M13 and earlier, but not in M14.
Alan
I do believe that in the past you have requested users to post their worksheets, because we (in this case "we" includes both you and I) don't like to (a.k.a. are too lazy to) retype stuff
Werner_E25-Diamond IAuthor
Hmm, wasn't that the case with much longer sheets and expressions? Its so much easier to insert pictures just by cut and paste (the only improvement in the new forum).
Anyway, here's the sheet 😉
I hardly can image that I would not have come across that bug in the past, so I suspect it to be a rather newly introduced "feature". But then, I may be wrong.
Alan
I have the same result in Mathcad 15 M040 service release.
