Building Structural Design - Direct Design Moments and Flexural Reinforcement
Chapter 6: Reinforced Concrete Flat Plates, Part 1
Description:
          This application calculates the service loads, the factored loads, the bending moments and the required flexural reinforcement for two-way reinforced concrete slab systems of uniform thickness (also referred to as "flat plates"), meeting the limitations of Section 13.6 (Direct Design Method) of ACI 318-89.
Next: Chapter 6, Part 2Previous: Chapter 5, Part 6
