Sep 19, 2013 12:01 PM UTC
Building Structural Design - Seism Loads Using ASCE Standard 7-93
Chapter 9: Wind and Seismic Loads on Buildings, Part 2
Description:
          This application computes the seismic forces, shears, and overturning moments at each level of a building, following the Equivalent Lateral Force Procedure of Section 9.4 of ASCE Standard 7-93. The building must meet the limitations for use of this procedure given in section 9.3.5 of ASCE Standard 7-93.
Previous: Chapter 9, Part 1
Next: Chapter 9, Part 3
Sep 28, 2026 6:53 AM UTC
Hello Tudor
This is really very good worksheet for seismic calculation. May you please provide mathcad file ?
DJNewman
Sep 28, 2026 1:30 PM UTC
Well, Tudor stopped working at PTC well over a decade ago.
I’ll get the Community admins on the task of seeing if there ever was a Mathcad worksheet for this post to begin with (it was migrated from the old platform), but I wouldn’t get your hopes up.
PTC Marketer for Creo and Mathcad. I run their YouTube channels, some Creo campaigns, and all Mathcad campaigns and communications.
terryhendicott
Sep 28, 2026 1:51 PM UTC
The original source is a Mathcad 15 E-book on Building Structural Design by Thomas P. Manger, P.E.
Here is the file that has Identical numerical values and formulas.  It just needs converting to latest Prime.
File dates from 2004 so there may be rule changes since then?
Sep 29, 2026 4:33 AM UTC
Dear ​@terryhendicott , ​@DJNewman.
I really appreciate your quick response and for providing the native file. Prime conversion works very well, and I will be sure to cross-verify it with the latest ASCE standards.
Also, just to inform you, I found a similar PDF for wind loads. It would be a great if the Mathcad file for the wind loads could be provided as well:
 Building Structural Design - Wind Loads Using ASCE Standard 7-93 | Community
Regards
terryhendicott
Oct 9, 2026 8:39 PM UTC
Sorry did not see your email until today.
Here is the wind load file.
Oct 12, 2026 4:51 AM UTC
Hi Terry,
It is completely understood, and I really appreciate your effort in providing the MathCAD file.
Thank you again for your support.
BR|
