18-Opal
Can I publish a Mathcad Prime File to Wordpress
Hi
Can someone help me with some pointers to achieve above.
Ideally - file can be dynamic  but will settle for a static file.
Sample file attached
Read please
Mathcad Calculation Server
18-Opal
None of these links work
23-Emerald V
One of these links works, namely the first one! There you can read that Mathsoft (the originator of Mathcad) once had the Mathcad Appolication Server (MAS), which allowed to show mathcad sheets on a web-page and actually  perform calculations with it. Unfortunately Mathsoft discontinued the product and since PTC took ownership no comparable functionality has been developed.
You should be able to use any Mathcad worksheet the same way as you can port them to MsWord: as a pcture.
