Can Mathcad Prime export equations as an image file?
If it is possible to export highlighted equations as an image file - then how is that accomplished?
Werner_EAnswer
PTC's implementations of cut and paste in Prime are a nightmare in many respects.
You should be able to copy and paste a single region to a word processing program or a picture editing program and save it from there. But it will not work with multiple regions in one go like we could do in real Mathcad - you have to do it one after the other.
You may consider using a screen capture program like  the Windows built-in "Snipping Tool" (WIN-Shift-S) or any other software like it (e.g. "Snagit").
Werner_E25-Diamond IAnswer
I ended up using a Windows screen capture utility (Snaggit) - and that works well for me.   Thanks for the help.
