Can someone help with the Find(x) function?
I have attached a pdf file with an explanation of what I am trying to accomplish.  The Mathcad file attached can be edited as needed.
-MFra-
Hi Derek!
I give you some advice:
dhanson-21-VisitorAuthor
F.M.
In the attached file I have prepared a revised format as you described.  However I am still not getting the values I would expect based on the individual calculations.  Can you look at the attached file and answer the highlighted question at the end of the first page?
Derek
-MFra-
But in the original file, you gave L = 0.3gal!?!? Now thou hast changed to L = 78in?!?!
So what is the unit of L? However, L is not used in the entire worksheet.
Here below is a photo of the original file with the changes I had made.
This is my opinion. I would like to know also the one of other people from the community. Let's wait for a while.
