23-Emerald V
Nov 15, 2019 11:01 PM UTC
Can't see your sheet, but...
Well, I could not, for a long time, view Mathcad 14 and 15 sheets. Unitil now.
For those of you who are in the same position: see attachment. Download, unpack, and execute it.
Yes, it's an .exe file. But go ahead and, before use, test it for viruses to ascertain it contains none.
I did not put any in, so please tell me if you find any.
On small sheet files it runs quickly, but larger files take time (seconds, minutes, tens of minutes). You'll just have to be patient sometimes.
Oh, and it does have bugs (couldn't name you one now, but I'm sure they are in there),
and things it can't do (yet...). It's a start, so far. (There's an 'info' text that you can double-click in the bottom-left corner)
But most of all, enjoy it.
LucMeekesAnswer
23-Emerald V
Feb 2, 2020 9:25 PM UTC
Updated.
- Will now handle Prime sheets to inform the Prime version it was created with (= the least version required to open it.)
- Improved feedback in the process of handling Mathcad 13...15 sheet files.
To handle Prime files a couple of DLL's are now required. They are contained in the .ZIP file.
Installation: Unzip the contents (1 .EXE and 3 .DLL files) to your directory of choice and enjoy.
Nov 16, 2019 10:22 PM UTC
Just tested, it works fine 😉.
7-Bedrock
Aug 20, 2020 12:06 PM UTC
hank you indeed vladimir I open it but I cant open it in the Mathcad I just show what is in the file , is there any method to open it .
LucMeekes23-Emerald VAuthor
23-Emerald V
Dec 17, 2019 9:12 PM UTC
Updated.
- Will now handle compressed sheet files (.xmcdz).
- Better feedback in the process, and afterwards.
LucMeekes23-Emerald VAuthorAnswer
23-Emerald V
Updated.
Dec 21, 2023 12:38 PM UTC
Dear LucMeekes,
Thanks a lot for developing this small application that opens old MathCad files. In my case I have some old MathCads worksheets with many useful calculations I want to retrieve. However, the collapsed regions are not possible to be opened and in most cases the key information is lost. Also, the error of region "Found a region tag named 'reference', please report" avoids opening the entire document.
Any new update of your fantastic program?
A million thanks!
G.
23-Emerald V
Dec 21, 2023 9:45 PM UTC
Can you post the worksheet file that caused the message?
(Or send it via private message...)
7-Bedrock
Aug 20, 2020 12:05 PM UTC
Thank you indeed for your help
