Cannot copy multiple math regions from within a text box
I am using Mathcad Prime Release 8.0 and Datecode8.0.0.0
How do you copy multiple math regions which are within a text box with intervening text to an area outside the text box. I wanted the copied regions to be separate math regions. The only way I found of doing this is to copy each math region separately. Is there a quicker way to do this?
Werner_EAnswer
Unfortunately there is no easier method than to copy  the math regions one by one. Ctrl-Click to select individual regions does not work inside a text region.
Copy and paste is implemented in Prime in a very silly and uncomfortable way in many respects. Think about copying values from a larger vector - its not possible unless you enlarge the vector to its full length.
The same applies to copying from a sheet open in Prime 10 for instance to a sheet open in Prime 8 (to accomplish the 'conversion' of a sheet from Prime 10 to Prime 8 format). This also can only be done one region at a time.
So what should we say  - its a PTC software ...
Werner_E25-Diamond IAnswer
