CFFT and a sanity check
to all
Doing a sanity check on the CFFT for another spectrum analyser in a 1/3 party tool
If one has a sine wave Asin(w*t) then a spectrum analysis will return an amplitude a=A/2 at w (or f= 2piw) . Am I correct?
Therefore if one only has the spectrum as an output (and not the original time signal) then one can read the frequency (w or f ) and conclude that the sine wave at the freq (in the time signal )has a peak value 2a!
Thanks in advance
John
LucMeekesAnswer
23-Emerald V
The output of all discrete Fourier transform functions is scaled.
Apparently dft (and dftr) is scaled by n/2, where n is the number of samples of the input vector:
You can investigate that by changing Tobs, Fs and A1.
23-Emerald V
Mathcad (the real thing) used to have several implementations of the discrete Fourier transform:
fft, cfft, FFT and CFFT. they differ in scaling factor and whether or not they work with arbitrary sized vectors or 2^n size.
In Prime these functions are deprecated (but may still work), and the preference now is to use the dft and dftr functions.
In the online help (search term CFFT) you can find an overview and comparison of all these functions.
JXBWk14-AlexandriteAuthor
Looking at the example: Example: Filtering in the Frequency Domain  especially the one 'Signal without Noise'. Playing with the input signal as per the example one can see the frequencies (of the signal changing (if one changes the w values) but the peaks value are odd. the the amptidues of both wave is 1 then 300 is returned as apeak, ampltidue 0.1 peaks ais 250
Jsut not sure what the tool/function is doing here.
Ultimatly one is lookgin to get the spectrum of the signal
LucMeekes23-Emerald VAnswer
23-Emerald V
