Chemical and Process Plan Engineering
This collection of 25 worksheets is divided into two sections: Chemical Engineering and Process Plant Engineering. The worksheets give example calculations for Chemical and Process Plant Engineering such as physical process balance, energy loss and savings, design for steam lines and pressure vessels, and other such areas.
