Cholesky decomposition & the LDL decomposition. finding D?
to all,
A question regarding the Cholesky LDL decomposition.
given a matrix A one can have A=LDL* where L* is the transpose of L
using the mathcad 15 cholesky(A), how does one code mathcad to get D?
L = cholesky(A)
Thanks in advance
Josh
Werner_EAnswer
The LDL decomposition is not Cholesky, rather a slight modification of it with the benefit of not having to take the roots.
But its very easy to get the LDL once you already have  the Cholesky decomposition:
You may now define a custom LDL function which does exactly these few steps
What D
Cheers
Terry
LDL Decomposition is not available it would be necessary to program it.
•Cholesky—Cholesky square root of a matrix
•LU—LU factorization into lower and upper triangular matrices
•QR—QR factorization into an orthonormal and upper triangular matrix
•svd—Singular values decomposition
Solve a linear system of n equations in n unknowns using the lsolve function
Werner_E25-Diamond IAnswer
Thanks a lot for that @Werner_E .
I was looking at pre & post multiplication ! Something like L^-1 A (L*)^-1. but you ends up with a "diagonal" matrix with unit value
If you mean by L the result of the cholesky function, this should  not be surprising. When the decomposition is S=L*L^T, then the only matrix you could squeeze in between using the very same L matrix is the identity matrix I -> S=L*I*L^T.
An additional advantage of the LDL* decomposition over Cholesky is, that it can also be used for indefinite matrices. But the approach I showed will of course not work ib that case because I am using the built-in cholesky() which will only work for positive definite matrices.
A more general LDL() function would have to be implemented in a different way without using cholesky().
