Coefficient result in square parentheses
Hello.
Why is the calculated value given in square parentheses? Is there any specific reason for it?
Best regards, Sergey
Werner_EAnswer
As I guessed! 😉
When you defined C.17 and all subsequent variables you uses square brackets where you rather should have used parentheses! So you created all these variables as 1x1 matrices.
Note the difference:
ttokoro
t.t.
Sergey15-MoonstoneAuthor
Thank you. But what is the reason for square parentheses?
Why do you think that we can tell you that just from the pic you posted?
We don't see if you use vector indices or literal indices, we don't see how you defined A and C, ...
Post your sheet and chances are that you get an explanation why your result is a 1x1 matrix.
