2-Explorer
Collapse / expand all areas
Hi, does anyone know of a way to collapse all areas in a document at the same time? I have a very large document with lots of areas in it. I have a need to open and then close them all depending what I’m working on and who I am showing it to. It takes a really long time to go through and click on all the + - signs. It would be great if there was an “collapse / expand all” shortcut or something…?
I do not think this is possible.
Collapse / Expand all would not work for what you described. It sounds like you want to open certain areas based on certain criteria, which again cannot be done.
oguest2-ExplorerAuthor
2-Explorer
OK, thanks. I would be happy with the ability to open or close all. If there are one or two area that I need different, that is quickly fixed manually. But opening and closing 40+ areas is a pain
I fully understand your pain. Without seeing the project it is very difficult to suggest workarounds.
