Oct 9, 2013 3:03 PM UTC
Combined Radiation and Convection
- 0 replies
- 1351 views
- Translate All
Description:
Radiation heat transfer rarely occurs by itself in a building. It is usually coupled with convection. Several such cases are considered in this section.
First, we determine the total U value of a double-glazed window, and the radiative and convective heat transfer coefficients in a cavity. Then, we consider a thermometer, which is used to measure air temperature, and determine the error caused in the measurement due to the radiation effect. Finally, combined radiative-convective heat loss from an exposed pipe is calculated.
