combining two matrices column by column
I have two matrices in Mathcad 15 with the same number of rows each and the same number of columns each. The number of rows and columns are not fixed.
I want to obtain a combined matrix, as indicated below, where C1, C2, C3 are columns:
MatrixA_C1    MatrixB_C1    MatrixA_C2    MatrixB_C2    MatrixA_C3    MatrixB_C3    ...
See attached example in Mathcad 15.
Thank you,
Otilia
Werner_EAnswer
Here are two functions to achieve the desired result.
The two matrices must have the same dimensions (same number of columns and rows) - there is no error check built in.
23-Emerald I
You can address each column of each matrix, A<0> means the zeroth(first) column of matrix A.
After that you can use the augment command:
result := augment(A<0>, B<0>, A<1>, B<1>,   )
For any single case you could write it out, for general use you could program it.
Werner_E25-Diamond IAnswer
Here's another option:
Alan
Otilia1-VisitorAuthor
Thank you, the two solutions that consider x number of rows and  y number of columns work perfectly with my case, but  I can use the function for multiple variables which i have in the same calculation file (density, enthalpy, entropy).
Otilia
