Command not be considered when numbering i=j
I have just learned to use programs to write calculations.
and I have 3 questions
1.How can i write command to sum value in table from column A to column B
2.How can i write Command to not be considered when numbering i=j
3.How can i choose the lowest value from table with numbering
Thankyou
Somkung
The attached sheet should help
Somkung1-VisitorAuthor
thank you for the answer.😀
But for this "not be considered when numbering i=j"
I mean i would like to skip calculate when i = j only (Calculcate by Given i=/= j )
i have more some question
Please see my new Mathcad again
You have a calculation using indices i and j and so you create a 2-dimensional array.
You must decide which value you would like to see in this array at the diagoinal, where i=j.
In my examples I had chosen NaN ("Not a Nuber") as 'value' but you can change it for anything else. You can use a reals number (e.g. a zero) or even a text string. But you can't leave it empty!
