Consolidation formula with montecarlo simulation
- 2 replies
- 1510 views
- Translate All
Hi
I'm trying to make a sheet for consolidation of soil with probabilistic analyses using montecarlo function.
As attached is a sheet of my initial try, but the formula doesn't compute even if
the units are totally dropper off from the matrices.
Can this type of relatively simpel formula be used,
or do I first need to make a vector of ech parameter with the random fluctuation?
The aim is that in final stage the units could be used in the formula.
