Continuous Beam Analysis - Stiffness Method
- 15 replies
- 9229 views
- Translate All
Hi everyone!
I'm sharing with you this worksheet hoping it will help you extract moments, forces and supports reactions from the continuous beam (>=2 spans) for further beam design according the codes you use.
Please let me know if you find errors or want to improve the code (calculation time is around 1 min for a 5-spans beam).
Alvaro Gavilán
(edited 30-09-19: tolerance adjusted in 9. Shear force equation)
