Conversion of Mathcad calculations to C-like code
Good afternoon.
Can you please tell me if there is software for converting the calculations made in Mathcad to a C-like code?
Or maybe there are libraries under Mathcad for this purpose?
The task is to transfer the "model" described in Mathcad to the code in any of the higher-level programming languages.
23-Emerald I
This question has been raised many times before.
In "old" Mathcad (before Prime) I don't believe there was ever a good solution presented.
There have been none in Prime either.
Try Maple for this instead
Some old topic "Generate C++ code from a Mathcad model": https://community.ptc.com/t5/PTC-Mathcad-Questions/Generate-C-code-from-a-Mathcad-model/td-p/174755
