Conversion of xmcd and mcd files to Mathcad Prime
Mathcad Prime 6.0 xmcd, mcd converter fails to covert files created with Mathcad 14.
    Werner_EAnswer
    Thats what i was talking about in my first answer.
    Did you look at the xml file your posted? Its the protocol of the conversion and contains the error message
    "Mathcad 15 M010 or a later version is necessary to run the converter. Please install the latest version of Mathcad 15 and then restart the converter."
    You need to download and install Mathcad 15 to be able to convert files from real Mathcad to Prime.
    If you bought a license for Prime you are also entitled to use Mathcad 15.
    Can you attach this file here?
    Here it is. Thanks for looking at it.
    Werner_E25-Diamond IAnswer
    What exactly do you mean with "fail"?
    You know that the converter needs a full working installation of the current build of Mathcad 15?
