23-Emerald V
Convert function name to string?
Noticing in Prime Express that evaluating a function name yields a string, ...
I was wondering if anybody knows of a way to save that string to a variable?
(This is something that I asked for since about Mathcad 11 - it would have been quite handy to have when, say, evaluating a list of functions or identifying a function that's stored as an array element)
23-Emerald V
The obvious doesn't work:
Unfortunately the variable 'a' is NOT a string, as shown by:
(Complains that "This value must be a string")
Instead, a is now (also) the sine function:
Note: This works the same way in Mathcad 11:
23-Emerald V
Thanks, Luc.
I already tried your suggestion, even though I knew it wouldn't work (otherwise assigning functions to names wouldn't!!), but I was wondering if there was some operation that would do the job, eg, something along the lines of converting a range variable into a vector, ...
23-Emerald I
You might be able to do it in a program
       name <--sin
  return name
Constrained to Express, I can only speculate. . .
