Jul 9, 2021 4:26 PM UTC
Jul 23, 2021 12:08 PM UTC
I have a student license for Mathcad, does that mean I have to buy a different license to be able to use the converter?
23-Emerald V
Jul 23, 2021 1:03 PM UTC
If you have Mathcad Prime 7, the converter is built-in. If your Prime version is  any of 1 through 6, you need mathcad 15 to be installed on the same PC, and licensed. You can use the very same license file for Mathcad 15 as you used for licensing your Prime.
Once Mathcad 15 is installed you should be able to use the converter.
For installation information see here.
