3-Newcomer
May 14, 2026 8:42 AM UTC
convert .xmcd file to .mcdx
HI i dont know who i cant convert the file from xmcd to mcdx. can some kind soul help me to convert it ?
3-Newcomer
May 14, 2026 8:44 AM UTC
oh? attachment should be a ZIP type? where is my .xmcd file
May 14, 2026 9:04 AM UTC
Try attaching a zip archive with files.
23-Emerald V
May 14, 2026 1:40 PM UTC
You should also state which version of Prime you are using.
Note that if you are using Prime 7 or higher, you can do the conversion yourself with the built-in converter. If that option is greyed out, you simply forgot to install it (By default it is NOT installed). You can re-install your Prime, don't forget to tick the conversion option On when you do so.
