Convolution - weird effect - and high res fwhm (Mathcad15)
- 1 reply
- 1656 views
- Translate All
Hi. I am trying to determine the width that a 1.1um object would appear when imaged through a microscope and detected onto a camera. This involves the convolution of 3 functions - the psf which quantifies the optics performance, the bead object itself - modelled as a top hat, and the detector pixel response again modelled as a top hat.
I cant understand why the artefact appears when I have a span of 100 but doesn't when the span is 80.
Also I perform the fwhm calc (via gaussian fit) on the pixellated image. How would I more accurately perform it on the high resolution image and express the result in um.
