Jun 24, 2011 7:19 AM UTC
Copy a field-vector into excel, or transform to a matrix
Hey Guys,
I've got a field vector (i dont know if it's the right english term.. the one which i get when i type in 100,150..2000 for example)
And i have to export it to excel, but when i use an excel component Mathcad only copies the last value (2000 in this example)
So my question is, if there is an quick&easy way to:
copy the whole "field-vector" to excel (without marking the values manually)
or to transform the field-vector in a "normal matrix/vector".
Greetings.
VladimirNAnswer
Jun 24, 2011 8:11 AM UTC
Take a look at the problem in the document for Mathcad 15. There is a difference between a matrix created using "Range variable" and without it. The document also shows the ability to create files ".xlsx", containing the results of the calculations.
Jun 24, 2011 7:29 AM UTC
Hello!
Could you upload your worksheet?
Jun 24, 2011 7:32 AM UTC
Of course, here you are!
VladimirN24-Ruby IVAnswer
Jun 24, 2011 9:59 AM UTC
Are you using Mathcad 15 & Office 2007?
Mike
Jun 24, 2011 10:08 AM UTC
No, Mathcad 14 and Office 2003.
But the example file from Vladimir works fine.
Jun 24, 2011 10:16 AM UTC
Ok, if your happy with that example I will leave it there. I was going to pass a few examples of exchanging data between Mathcad and Excel using scripted components, as I have collated a large collection over the years.
On another note have a look at the attached. I have changed your range variable to a vector using a pre-defined function (vec) in the collapsed area. It's good practice to keep away from range variables for later use (Well in my opinion anyway).
Mike
