CSPLINE and iteration
  • February 19, 2014
  • 13 replies
  • 4271 views
to all
I am looking at some programme which will involve curve fitting (possibly). I had a look at the doc and it seems quite straigforward but I am not getting what I expect when attempting a plot of the cspline. The overall problem is explained in the attached mcad (can't copy and-paste)
Regards
JXB
The attached file should help with cspline and linterp
thanks Werner. Make sense now!
How does one interpolate between 2 sets of known data then? For example (see also attached) if one has data for a ratio b/d=0.1 and b/d=0.2 but one wants a Y value (K on the mcad sheet) for say b/d=0.164? Should one construct a "dummy" curve (spline) between thw 2 sets of data
basically - yes. You are asking for a 2-dimensional interplolation. Guess the attached sheet should help.
Werner
What does the function f(p,bd) do? I think I get the other 3
Regards
JXB
