Curve fitting/Interpolation question
How to find a function that fits to below data. This function is a resistance temperature dependent that will be further involved into another equation (Vout(Temp)), and then how to plot Vout(Temp) vs Temp? Temp is temperature, lets say from -60degC to 90degC. Mathcad Prime 9 fille attached.
Werner_EAnswer
As Fred already noticed you mixed up angle degree with degree temperature, presumably °C.
Now you have the choice between an interpolation (the "curve" runs exactly through the given points) or a curve fit, where you choose a function type and Prime tries to adjust the parameters so the overall failure is minimal (least square sum).
The simplest interpolation sure is the linear interpolation:
You may also try a spline interpolation which sometimes is appropriate but sometimes leads to undesired effects
As for a function fit you first would have to decide for a specific function type. Fred decided for a polynomial.
I guessed that an exponential fit might be appropriate. I use the generic "genfit" function for demonstration, but fo a simple exponential fit you may also use the built-in "expfit" function ("expfit" will also accommodate for a vertical displacement).
Note that the standard unit for temperature is Kelvin and its always a good idea to leave it at that because working with temperatures may be quite nasty using °C. So R0 is the resistance at the absolute zero (0 K) and thats the reason for the huge guess value of 100MOhm.
You also can see by the calculation to the right of the first plot that the curve does not run through the points exactly but rather fits them best.
Prime 9 sheet attached
23-Emerald I
Attached is an Express 4.0 sheet.  A place to start, obviously not quite the right function.
Werner_E25-Diamond IAnswer
Addendum:
If you feel like me uncomfortable with the guess value at 0 Kelvin you may use a slightly different function which is shifted by 0°C. Now R0 is the resistance a 0°C which can be guessed from the given data to be around 5 kOhm.
Cornel19-TanzaniteAuthor
@Werner_E What will be the value for
Werner I need the function R1(Temp)...what are the constants a0 and a1:
ttokoro
Using your  data, I try to curve fitting by below functions.
At first I made interpolate data by log(time).
Then try to use expfit, polyfit, genfit, etc..
Finally, rationalfit can fit both magnitude and phase data.
t.t.
Attache the sheet..
ttokoro
I still study Rational Function Regression. You can find it by Mathcad help.
rationalfit(vx, vy, conf, m, n, [Stdy], [LBUB], [Acc], ["noscale"])
m=5 and n=5 are OK to fit well.
t.t.
