Curve fitting using a numerically-solved equation
- 12 replies
- 5041 views
- Translate All
Dear all,
I attach here a numerically-solved equation code for you. The tuning parameter in the code is alpha (alpha:=2.4/1.764). What I usually did for my work is to choose different alpha values and to generate the data of gdc vs. t/t_1618. I compare the generated curve to my experimental data and I justify the correct alpha values by naked eyes. Is it possible to modify my code to import the experimental data and let the Mathcad find the alpha value from a least-square fitting?
I really have no idea how I should do that. Could anyone give me some help please?
With best regards,
Chien-Lung Huang
. Here it is though.
