Data Analysis - Problems
- 0 replies
- 4398 views
- Translate All
This section contains two closely related problems that deal with data analysis. You will need to use descriptive statistics, graph data, and use linear regression to fit a straight line to the data.
If you have difficulties in figuring out how to proceed with the problems, refer back to the Tutorial and Exercises and use the worked examples as a guide.
