Data Import Wizard
I used the data import wizard to read data into a table in a Mathcad file. Works fine on my system. However, when I upload that file to the PTC site the data in the table is stripped. Anyone else run into this and is there a fix ?
23-Emerald I
March 7, 2012
Any part of Mathcad that is going to read a file on execution will fail when that file isn't wherethe component expects it to be. If you post the mathcad file AND the read file, AND the reviewer downloads both, and saves them on his computer, and opens the component and corrects the path, then the import wizard will work.
If you want to put data into the mathcad file so that the mathcad file is self-contained, then you can either type it in or paste it into a data table. (Which is what I wrote in the other post!)
Joeboy1-VisitorAuthor
O.K. Fred I uploaded both the Mathcad file and the data set. Try it and see if it works, thanks for the help
23-Emerald I
March 7, 2012
Dixie,
You put in a blank data table.
I put the data into the data table; now this file stands on its' own.
