detección de figuras descriptores de Fourier
need help detection figures Fourier descriptors is for a science project
23-Emerald V
I think you need to give us a bit more information than that! 🙂
What are you trying to do and how do you intend to use the Fourier transforms?  Which version of Mathcad are you using?
Stuart
I need to recognize the type of figure geometric for the number of sides, perimeter and area by discrete Fourier transform one-dimensional
23-Emerald V
Interesting.  Do you have a particular range of geometric figures in mind (I'm guessing regular polygons, but maybe you want irregular polygons as well).  How do intend to express the data for each figure (eg, radius versus angle about some point internal to the polygon, length of each side and associated turning angle, array of (x,y) vertices)?  Do have a model for doing the analysis or are you looking for ideas on that front as well as how to implement it in Mathcad?  What version of Mathcad are you using (it may make a difference if you're using Prime rather than, say, Mathcad 14 or 15).
Stuart
May by this on Mathcad Server
http://twt.mpei.ac.ru/MCS/Worksheets/Fourier.xmcd
