Determine the center and radius of the circle of the triangle
I a'm a student and i need help witch task
Given a triangle defined by 3 points with coordinates
(x1, y1) (x2, y2) (x3, y3)
Determine the center and radius of the circle of the triangle. Draw a triangle on a graph and a designated
circle.
i don't understand this
sorry for bad english
You are being asked for one of these:
http://www.mathopenref.com/trianglecircumcircle.html
http://www.mathopenref.com/triangleincircle.html
but it's not clear from the question which one.
Looks like home work, doesn't it?
Why not show what you have done so far? If you have problems in one stage of your sheet I am sure you can get help here.
