Werner_EAnswer
Maybe using "explicit" does what you want. n must not defined a value to make it work.
You can also make it look like this
What do you mean by "the index for each W based on the n value?" The index is either n-2, n-1, n, n+1, or n+2.
SFares14-AlexandriteAuthor
for example to display when n=3, to plug in that value and get or display W1,W2,W3,W4,,W5 .
Werner_E25-Diamond IAnswer
Thank you Werner!
every time i use subsitute, do i need to use explicit with it?
Werner,
why doesn't it work if i define a value for as i did earlier, and then use explicit, n w/o subsitute? just trying to understand how things work!
