ttokoro
Divide a surface into equal sized areas
Puzzle only to fun. Question graphs are made by using Mathcad programing.
Divide a surface into two equal sized areas by using matchsticks.
1. With using two matchsticks.
2. With using three matchsticks.
3. With using n>3 matchsticks.
lvl107Answer
20-Turquoise
Ttokoro, it seems like this ? :
   Loi
23-Emerald V
That's a no-brainer. I have very large match-sticks, so I can divide the triangle into two pieces of equal size with a single match-stick, using a variety of positions of the stick.
And if it can be done with one, it can be done with any number of match-sticks.
But I think that's not what you're after, and you implicitly assume some rules that you have not explained.
23-Emerald V
Assuming that only match-sticks with length 1 may be used, and they must be only inside the triangle, here is a solution for 2 match-sticks.
Here's a second solution using two match sticks:
An additional puzzle: Using four matchsticks divide the triangle area in three areas of equal size.
ttokoro
ttokoro21-Topaz IAuthor
Good answers!
Both of you using Mathcad and it will be help for Machcad usage for the users.
Match stick puzzle usually use unit length 1 and it put on dot points on the figure of the stick top or bottom.
Or the position can be fixed by using match sticks.
If you got two and three stick answers, you can arrange them any number of this problem.
Then, using 12 all sticks in my picture and move two or more sticks to reduce the area size from 4*3/2=6 to 5, 4,3 and 2. I don't know the answer the area size is 1. Of course the minimum movement number of the sticks are the good answers.
 Tokoro.
t.t.
ttokoro
The one of 3D.
t.t.
20-Turquoise
Ttokoro, It seems something like this :Half_Vulume.PNG
Best Regards.
   Loi.
