Dividing a vector by a constant and assigning it to a new variable issue
@Werner_E wrote:
3) Use a small program to create vectors of your choice - you can chose to use the same argument order as in the definition of a range.
Similar routines also were posted here from time to time and a command like this should be part of Mathcad/Prime out of the box. Unfortunately it isn't.
I see that the topic is from 2016 and it is now 2024 but i had basically the same issue. Have i to conclude that it is still not fixed to create easy a vector in some range?
Initially posted in this topic
LucMeekesAnswer
23-Emerald V
It's very easy to create a vector in some range. Some examples:
Digits := matrix(10, 1, max)
produces a vector with all digits 0 through 9
Tens := (matrix(10, 1, max) + 1) * 10
produces a vector with the numbers 10, 20, 30...100
I am not sure if there is anything to be 'fixed' concerning the creation of a vector.
I made a few suggestions, the easiest seems to be the undocumented trick to turn a vector into a range.
A small user-written program to create vectors might be useful so you can fit it to your needs - e.g. it could take the first, the last value and the stepwidth instead of the second value. Or first and last value and the number of elements you need.
Guess there can't be a built-in function for every need we could think of...
LucMeekes23-Emerald VAnswer
23-Emerald V
Nice idea!
Could be turned into a utility function where you provide start value, step width and number of elements:
