Down convert Mathcad Prime 3.0 file to Prime 2.0
Is it possible to downconvert a Mathcad Prime 3.0 file to Prime 2.0?
I have Prime 2.0 at work, but at home I downloaded the free Mathcad Express + 30 day trial. The version I have at home is Prime 3.0. Every once in a while I come up with an idea at home but don't have my work computer with me. I'd like to be able to e-mail the file to myself and use it at work. However, when I attempted that today I couldn't open the file at work using Prime 2.0.
Any ideas?
Werner_EAnswer
Any ideas?
Other than upgrading the version used at work? Yes, downgrade your homeversion. Try to get the installation version of the Prime 2 you use at work, deinstall P3 and install P2. It will fall back to Express, too, if you provide no valid license file.
No.
Any ideas?
Complain to PTC. It probably won't get you a solution, but it might make you feel better
Werner_E25-Diamond IAnswer
Any ideas?
Thanks Werner. I'm sure that'll work. Not exactly elegant, but at this point I'm simply going for practical.
