Echo an equation
This should be simple.  I have an issue where I define an equation and get a useful result.  But further down in the mathcad sheet I just need to echo the equation that defines the variable to the user so he can make other determinations from the equation.  How do I do that?  See attached.
I need the means to do this in Mathcad 15 and in Prime 8.0.
LucMeekesAnswer
23-Emerald V
In (real) Mathcad, like this:
ttokoro
From help page of explicit.
5.To perform the above numeric calculation without using explicit, use the clear.sym function to clear the symbolic values of all variables:
6.Use explicit to display formulas in terms of variables, without substituting values for the variables defined elsewhere in the worksheet:
t.t.
I see how this may be used.  I don't see the mechanics of how to implement it Mathcad 15.  See below example in Prime 2.0 in attachment
ttokoro
t.t.
23-Emerald I
Do you mean like this?
  • Copy the equation, paste below..
  • delete the trailing evaluation " ="
  • REPLACE the defining " := " with the boolean comparison equal " = "
Works in any Mathcad.
LucMeekes23-Emerald VAnswer
23-Emerald V
No success yet.  See attached.  Maybe there is a default in Mathcad 15 that needs to be set?
Hope this helps:
MC15 file attached
