Edit XML file for using floating license
Hello. We have server with 2 floating licenses
I try to create xml file for silent installation,but I have two questions
1. I as administrator created xml file, after first installation (mathcad.p.xml)
I have edited xml but one line
<PROPERTY name="[APPLICATIONDATA]">C:\Users\Admin\AppData\Roaming</PROPERTY>
I dont understand what have to be instead of Admin, I think CurrentUSER but how it will look like?
<PROPERTY name="[APPLICATIONDATA]">%Currentuser%\AppData\Roaming</PROPERTY>
or something else?
2. Second question is:
Could you help me to edit this line
<MSIARGUMENT>LICENSEPATHFORM="ServerAndPort" LICENSEPATH="7788@localhost"</MSIARGUMENT>
Our server fpr example Server port 7788 how will be right:
<MSIARGUMENT>LICENSEPATHFORM="Server:7788 or Server@7788" LICENSEPATH="7788@localhost"</MSIARGUMENT>
Thank you for your answers.
Finally I have found someone who asks kind of the same question but then this post is 6 years old and unanswered too!
I'm trying to make a silent installation of mathcad prime 7 here and the installation itself seems to work, the program gets installed.
When I start the programm it prompts the licensing window, even though I edited the mathcad.p.xml file in order to automate that step for our users.
I tried
<MSIARGUMENT>LICENSEPATHFORM="servername:7788" LICENSEPATH="7788@localhost"</MSIARGUMENT>
and I also tried servername@7788 but the problem remains, I can't license an installation automaticly.
Am I missing something here? Do I have to change the licensepath aswell?
23-Emerald V
See if you find help here.
Thank you very much for the reply and sorry for hijacking this old post.
Sadly I can't find anything about silent installs or the mathcad.p.xml file under that link you provided so I'm right where I started.
